Continued to clear brake lines. Found out we were using a pump that was introducing air into the lines as it pumped fluid into the system. Switched to a small squeeze pump. Have been checking lines each day for any additional air bubbles and then flushing more fluid thru the lines. Can't install front cover until we are sure lines are clean. Tapped baggage area platenuts and installed back baggage covers to complete baggage area installation. Temporarily added our Flightline Interiors back cover to see how it looks. It has a tonneau cover that we may or may not use. It also has the obligatory 'EXPERIMENTAL' sewn into it. Replaced the tip-up canopy to test and finalize fit. Fabricated two guides to guide the canopy into locking position. Drilled guides and painted them, now ready for installation.
