Installed canopy guides, then re-installed canopy to test guides. Work fine! Reviewed all items under forward top skin to make sure ready for riveting top skin. Reworked canopy release pins to make sure fit snugly and pin fully inserted. Checked clearance of canopy extensions under forward top skin to make sure no interfenece. Worked on adjusting tabs on forward sub-panels to get good fit with canopy forward skin. Pro-sealed cutouts on sub-panels for a clean appearance. After pro-seal dried, touched up paint on forward sub-panels prior to riveting. Dimpled forward top skin. Ready to rivet top skin! Moved painted wings, flaps, and ailerons to new hangar at airport.
