Final mounted EFIS/EMS. Connected pitot and static lines. Tested both pitot and static ports on EFIS - worked OK. Checked EFIS altitude output to transponder. Found ground line not connected. Corrected and tested altitude output to transponder. Works as desired. Now only need to connect AOA lines to EFIS/EMS - will do that at final assembly of wings. Finalized wire cables behind front panel, ready to close! Began filling brakes with brake fluid. Tested all brake fluid connections and no apparent leaks. All brake cylinders appear to work OK. Still have some small air bubbles in the plastic lines. Hope to get some 'expert' advice on how to proceed with those.
