Deburred entire top panel and wing ribs. Sprayed all contact surfaces with zinc corrison spray.Drilled holes for rubber gromets for wing tip lighting. Pulled wire through holes.Nicro press 4 thimble ends for ailron controls. Vaccumed wing out and reinstalled top wing panel with clecoes.
1/8 cable nicro spress tool
top panel leaning against work bench after deburring
