Brief Description: Rivet the Rudder Stop to the Rudder Yoke
Step 65 : Rivet the Rudder Stop to the Rudder Yoke
Apply the corrosion-protection of your choice to both the stop plate and the holes drilled in the rudder yoke. When the corrosion protection has cured, Cleco the rudder stop to the rudder yoke. Make sure the stop plate is right-side-up (with the arms angled downward) before riveting. Rivet the rudder stop to the rudder yoke with 1/8" AN470AD4 universal-head rivets. Because of limited access for your rivet gun, you’ll have to install the rivets with the heads down. If you are building a taildragger, proceed to the next step; otherwise, set the rudder assembly aside.
