HB-YAK GS-2 Sportsman 2+2 kit
Sportsman 2+2
System Installation
8-21-2021
Step 98
Install the Steering Cables
Step 98: Install the Steering Cables (Taildragger Only)
Bulkhead E needs to be pierced to let the cable trough, but the laser points to the lowest screw of the elevator bracket - what to do ? I will check with my counsel.
Laser jig
hole in fuselage drilled
Laser pointing to spot to be drilled
Sportsman 2+2 Home
1748
288
Final assembly
126
535
System Installation
SYSTEMS INSTALLATION
312
