Brief Description: Fabricate and Install the Elevator Control Stop
Trim the forward edges of the elevator stop plate arms until they contact the polyethylene pads just as the elevator reaches its travel limits. Trim the right-hand stop plate arm to adjust the down elevator travel; trim the left-hand stop plate arm to adjust the up elevator travel. Drill two #30 holes through each polyethylene stop pad and through the aft laminates of Bulkhead C, as shown in Figure 199, being careful not to drill in areas where the stop plate arms contact the pads. Use 1/8" aluminum blind rivets [105] to secure the contact pads to the bulkhead.
