HB-YAK GS-2 Sportsman 2+2 kit
Date:  1-8-2022
Number of Hours:  3.00
Manual Reference:  Step 31
Brief Description:  Install the Strake Ribs
Step 31: Install the Strake Ribs
The four strake ribs run laterally across the strake and are spaced at roughly equal intervals. The
exact placement of Ribs A, B and C is very non-critical— they are essentially positioned wherever they fit best between the skins of the strake
Strake Rib D must be placed with a bit more precision to ensure that it clears the leading edge of
the stabilizer.
The templates for all four ribs were sized a bit over-wide so that they could be
sanded to fit. Do so now, removing just enough foam from the bottom edge of
each rib to achieve a snug fit between the skins
Note: The ribs should not fit so tightly that they distend the skins.
With the ribs friction-fitted between the skins, mark the centerlines of Ribs A, B and
C on the fuselage flanges of the strake. Then hold the strake in position against the
fuselage and stabilizer, carefully aligning its leading edge on the strake centerline
marked on the fuselage side. Reach inside the strake from the inboard side and
push Rib D aft until it’s tight up against the leading edge of the stabilizer. (You may
find this easier to accomplish with the help of an assistant.) Then remove the strake
(with Rib D still in place) and mark the location of the forward edge of Rib D on the
strake’s fuselage flanges. When you bond the ribs in place, center Rib D on this
mark; this will have the effect of moving the rib 1/4" forward, providing necessary
clearance between the rib and the stabilizer leading edge.
I add the bonding and Pascal positions the ribs
Pascal finishing rib D
Lets wait to see how they cure
