HB-YAK GS-2 Sportsman 2+2 kit
Date: 12-30-2021
Number of Hours: 4.00
Manual Reference: Step 17
Brief Description: Step 17: Fit the Floorboards
Step 17: Fit the Floorboards As indicated by the shaded areas in Figure 20, the floorboards cover the area between the rudder control weldments and the seat pans in a fore-and-aft direction, and between the fuselage sidewall and the forward control cable cover in a lateral direction. They are held in place at twelve attach tabs welded to the cage; the locations of these tabs are shown in the figure. Cut the floorboards out of 1/4" marine-grade plywood, available at any building supply store. You can also use lightweight composite panels for this if you have a local source for them, but this is definitely more expensive. Because of small but significant variations in the Sportsman cages, we are unable to provide templates for the floorboards, so make a pair out of cardboard for your own cage. Note that each floorboard must be relieved in three locations: at its forward end (Point A in Figure 20) to fit around the rudder control weldments; along its outboard edge (Point B) to accommodate one of the small, vertical tubes in the truss at the lower edge of the cage sidewall; and at its aft, outboard corner (Point C) to fit around the taildragger gear socket. Also note that the Point A cutouts are not the same left and right. Finally, take special care to get a tight fit on the inboard edges of both floorboards. This is where they contact the sides of the forward control cable cover, and to prevent the cover from rattling around, the floorboards should fit snugly.
