Brief Description: Finished right wing fuel system
Finished the right wing fuel system, which involved installing the tank in the wing with the cork strips, attaching the fittings for the fuel supply and return with the loctite and running hoses and wires. The hole in the rear spar for the fuel return line was cut out with a hole saw and a grommet was installed as with the fuel supply hose. The fuel sender wire was installed as well.
