Preped and readied the Phenolic block that is used to attach the flap motor. This is centered and adjusted a specific measurement back from the rear spar. 17+ inches is what is required. It is then floxed in place and left to cure. Later, we'll remove the motor, sand it down and add a bid that is 1" wider and longer that covers the block.
