The right side Slick Mag was removed and I installed the ElectroAir Mag Timing Housing in it's place. Used gear puller to pull off the drive gear from the Slick mag and install it on this MTH. A Top Dead Center Timing pin is provided and its simple to find the TDC alignment by rotating the device until the TDC pin enters the TDC alignment hole, stopping any further rotation. Next is mounting it after rotating the engine to TDC.
Stuff removed from the Slick Mag.
Install the Drive Gear onto the MTH.
Locate TDC and the Alignmnent Pin slips into place holding the position until you mount it.
