JAMESs Web Site
Date:  3-11-2024
Number of Hours:  4.00
Manual Reference:  15.2.4
Brief Description:  ZOLATON PAINT APOLLO GRAY to replace the vinyl
I ordered ZOLATON PAINT APOLLO GRAY to replace the vinyl I glued on that was coming off. I hate to say bad things about Aircraft Spruce but the 1 gallon can showed up rusted and leaking on the bottom. They should have never sent it out to me and sent back to were ever they had received it from. Email was sent off.
I am using what is left in the can and will get a new can from Lordco to transfer into.
I have applied 4 coats at this point. I just pull the brush to lay the paint down.
This paint is to be sprayed on but will never do this in the house because if there is a spark from static electricity the house will burn to the ground its one wicked stuff for fumes.
Co-Pilot side.
Co-Pilot side.
Pilot side.
Pilot side.
Back panel.
Back panel.
