I tried to keep the gap to a minimum but after getting it to fit the bottom was ½” to ¾” wide so I will need to fill in with one bid on the outside and add flox mix with 2 bids on the inside, this way I will be able to sand the correct clearance for paint. The fiber glass cowling can easily be fixed if things go wrong or just don’t fit.
