JAMESs Web Site
Date:  5-11-2015
Number of Hours:  3.00
Manual Reference:  14.2
Brief Description:  Prep for K2 primer and sprayed out 2 coats
Prep for K2 primer by sanding a few spots from last night and sprayed out 2 coats.
There are a few pinholes that jumped out at me spraying the primer on and I will fill the next time I’m working on the plane. I let the fans run to clear out the bleed off of the solvents and after a snack I got back to working on the speed brake filling.
Co-Pilot wing Primer on
Speed brake and Spot-Lite
