The aluminum block with 80 grit was put to work tonight working on a smooth straight transition. I used the brush to wipe away the sanding dust and not blowing off the wing as the dust is too much to handle. On my second Spot-Lite bondo application I changed the hardener color and this will help me with defining dept and edge blending. A few more rounds and the K2 primer will be used.
