Brief Description: Sand sealer primer and add Z Grip bondo
Tonight I sanded the sealer primer to find low areas and see the scratches in the Micro. The sealer is very hard and 80-120 grit was used to get the results I wonted. I then used Z Grip bondo to fill in the low areas and a few deep scratches. I will see how it sands out and if I’m not happy I will go to the Spot- Lite bondo and fill with this stuff. The wings were very close before I sprayed the sealer on so the bondo work should be fast and then the K2 primer comes out to play.
