Brief Description: Filling and sanding low areas on strakes
I am filling and sanding the low areas on the strakes and fuselage with Z-Grip and Spot-lite bondo. I’m starting to see the light at the end of the tonal it is a long way to get there but the light can be seen. I find that the Spot-lite 2 part putty is great to work with and shape with 80 grit sand paper. Z-Grip is used for the bigger areas needing filling. I still go back to sand able Epoxy and micro balloons for the very big areas needing filling or shaping.
