JAMESs Web Site
Date:  1-31-2015
Number of Hours:  4.00
Manual Reference:  14.2
Brief Description:  Blocked out primer with 3’ and then air board
I sanded the winglet filets and then move onto the strakes for 3’ blocking and then used the air board for easier work. There are only a few spots that need micro so once they are done and out of the way I will start to work on pinholes and deep scratches. I will also be working on the transition from the stakes to the fuselage side. Next on the list is also blocking out the wings one more time and get ready to cut the bottom ailerons before they get turned over.
Stakes are blocked out
Micro added in low areas
Just a few low areas need work
