Brief Description: Fit and glass in section on wheel well
This side has been trying to get right. The Pilot landing gear leg is over a bit into the fuselage which means it will rotate into the fuselage more then the other side and so the fitting was a bit more of a challenge then the Co-Pilot side. After cutting and sanding it is very close to where it should be.
