Brief Description: Install front and rear throttle quadrants
- Final installed the front and rear throttle quadrants. Took alot of dremeling the bulkhead holes and getting the geometry correct for the the inter-connect rod. After alot of tedious cycles of removing quadrants, carefully opening holes just enough so as not to removed too much material, re-installing quadrants and checking, I finally got it all adjusted and working to my satisfaction. Both the front and rear throttles have a nice smooth flow to them.
