- Verified the stick control column bearing heights were adjusted per the plans. - Determined the roll binding in the control column occured when the final torque was applied to the bolts holding the forward control mount to the center wing section. So I made a .020" shim to fit between the mount the center wing. Upon reinstall and torquing, the center column binding the roll was gone! Now the sticks move smooth as silk.
