This post is summary of several work sessions taking care of various things.
-Purchased the mount kits for the Dynon autopilot servos, installed the pitch servo mount in the aft part of the fuselage prior to installing the aft skin.
-Made mounts out some angle, and a plate out of .041 sheet. Installed the mounts on the lower and mid longeron just aft of the F-808 bulkhead. This is where I will mount the remote unit for the Dynon transponder. It may also hold the ELT, if it's determined it will not fit within the empennage under the fairing.
-Using aluminum angle, I made two pieces that will serve as a mount for the Dynon ADAHRS. I located in just forward of the F-809 bulkhead. It'll be a booger to get to once the aft skin is on, but it's well away from any ferrous materials and near the static ports.
