-Located and drilled out the conduit holes to 3/4" using a uni-bit.
-Installed the corrugated conduit. Started in the middle and pulled it aft through the bulkheads, and forward through the wing center section into the LT LG box assembly. This was not easy work. Ended up with bruises up and down both forearms...
This conduit will contain the wiring for the aft tail light/strobe (shielded wire), and the pitch trim wiring.
Conduit run looking aft
Up through the aft deck
Snaking up through the left LG box. Exits behind the instrument panel
