Brief Description: Left Wing #37 - Drilled wing side flap hinge
Drilled the flap hinge. Decided to secure the hinge pin using the alternate method so the flap can be removed without removing the aileron. So I removed hinge eyelets near the middle on the wing side of the hinge, and one on the flap side. Bent and cut the hinge pin(s) to length.
