After cutting my strips of matt, I mixed up 8 oz of the special resin that makes this stuff kick. Turns out I should have gotten thicker matt. This 1-1/2 oz matt is pretty thin. I added 8 layers to the thick part. Not sure if that will be enough until test fitting again.
I was able to do the left and right sides, but ran out of resin before I could extend the center aft. Fibers are everywhere, so I'll let this cure and then do the center. Don't want to mess up what I've already completed.
