Brief Description: Right side VS Spar bolt and nut
I obviously learned a thing or two installing the left HS Spar bolt and nut because the right side only took 30 minutes. I started by opening the access hole a bit. The washer did not need to be ground because the edge of it slipped in the gap between the spar and the VS. There was no big epoxy glob on this side, so that made it easier too.
If I were doing this again, I'd make the spar hole a bit bigger on both sides (maybe 1/16") to provide a gap for the WAW to slip into.
