I received the wire harness for the CHT probes (Cylinder Head Tempeture ) This is a air cooled engine and you have to make sure there is enough air flow so the engine does not over heat. The probes have been installed along with the harness and checking it out on the engine screen it was 3 probes the same tempeture and the 4th only 1 degree different so that is good.
