Worked a few days on installing the engine oil breather and hoses. In pic 1 you can see the black hoses going to the top and bottom of the collector. Any oil that comes out of the breather goes into the black funnel shaped part through the top hose and then will collect and drain out the lower hose and back into the engine. I still need to attach another hose to the top that will direct any fumes from the engine out through the bottom of the plane. In Pic 2 I have put a label on one of the wires and then put a piece of clear heat shrink tube over it to keep it in place. Then you use a heat gun to shrink it to make a nice tight fit.
