Did some of the wiring for the fuel pumps. There are different size nuts on the negative and postive posts on the pumps so I had to make another trip to get metric nuts. I wired the circuit breakers for the ECU ( engine control unit ) and each fuel pump. I still have to wire the positive wire to each pump and the main feed wire to the battery. I put temp wires to power to check it out and all the lights came on with the switches so I'm pretty sure it's all good. Installed the CHT's ( cylinder head tempature ) probes . I have to check to see if I need special wires for the hook-ups In picture 3 you can see the wires coming out on each side just above the dark covers and one on the left upper side and the other on the right upper side.
