Brief Description: First part of the day on fiber glass work
Made filler pieces for canopy arms out of foam blocks. Glued them into position and then sanded to the contour of the plane. Taped off areas where you don't want the fiberglass to stick. Cut out templates to be used to cut the different layers of fiberglass.
