Installed trim servo motor and linkage to tailcone assembly and trim tabs. Checked for tailcone faring clearance where linkage goes through it. Hooked up stabilator cables to stabilator horns using lube on bolts and the proper hardware ( bolts, castle nuts,washers and cotter pins ) per page 32-13
