Brief Description: Place tailcone on and start fitting everything
Drill and install clecoes in 2 places to hold tailcone fairing in place using the marks on masking tape. Take tailcone back off and install stabilator. It was hard to get it aligned and bolts in without washers falling off. Used crazy glue to hold washers in place but 1 kept getting knocked off due to small clearance when sliding everything together. You need atleast 1/8 clearance between the stabilator and tailcone so you put it in place and mark it and then take tailcone off to trim the inside of the stabilator, then put back on and check again. Feels like it has been off atleast 50 times! You can see in picture 2 the hole inside the stabilator where the tailcone fits in.
