Brief Description: Run cables , work on nose wheel assembly
Run Stabilator cables to the tailcone. Install bushing and pullys. Will complete hookup after putting the stabilator back on. Put nose wheel assembly together and mount on plane. Need scale to adjust friction for the swivel of the gear. If it is too loose you will get a shimmy and if it is to tight you will have trouble steering.
