Took the main wheel brake assembly's apart and seperated the wheel rims. Installed the tire and tube for each side making sure to line up the red dot on the tire with the valve stem on the tube. This helps to get the tire balanced as close as possible. Bolt the two halve of the rims back together and carefully inflate the tires.
