Did not put noise filter at pump location because the pump will now be located on the firewall. Put in wie cover plate under flaperon control bracket but it didn't want to stay down. Had to put in shim under F-1276D system block for more pressure on plate. 31B-24 tap 8-32 threads in electrical brackets and install ES-00077 & 78 floating 8 pos connectors. Mount asemblies to floor pan and then the side covers to the fuselage skins. Attach foam strips to F-12125 over rudder wire way. Slide wireway over rudder pedal shafts. It slid in place easily but could not get screw into the hole and to nutplate without the wires in the way. There is no room to work or see anything ! Finally had to remove the rudder pedal assembly and get screw and wires into position, then slide pedal assemble back in and get it to line up for the mounting bolts to go in. Took about 3 hours time fighting with it all the way. The screw goes in between the pedal shafts where you can't see it or get in close to work.
