Brief Description: The never ending wire hook ups !!
Install the poweer outlet receptical and wires. Run the wires and install the headset jack modules on the left and right side making sure that the jacks sre not touching the airframe anywhere by using a multimeter to check continuity. There are small fiber washers to hold everything in position and no metal touches the module. Install the wing lighting wires into the ES-00077 and ES-00078 floating 8 pos connectors. Insert the proper wires into the pitch servo connector. Route the selected wires into the tailcone and connect to the autopilot roll servo connector. Finish routing of the rest of the fuselage and oat wires to the tailcone. Can not connect to plug because it is supplied in the avionics package which was shipped today and I should have it soon. About another day and the wiring section should be done until the avionics is here. Feels like you are getting no where fast !
