Tie wrapped the wire bundles under the avionics shelf and down through the tunnel to the rear. Attach the F-12125C Wireway bracket flange to the center pedal support and then tie wrap wires to 2 holes at the end. 32-01 & 2. Mount brake reservoir to firewall and attach brake lines as instructed. Install cushion clamp under shelf to hold the brake lines in position.
