Brief Description: lower wing skin attachment to bottom fuse skin
We attached the lower wing skin to the bottom fuselage skin. The wings have already been bolted in with the splice plates and about 78 bolts. We drilled 8 holes for each side from the bottom, then used #10 plate screws into a washer and lock nut. This is a two person job! We could not find these directions or instructions in the plans or drawings, just happened to read about it in the Vans forum. Apparently there are alot of airplanes out there flying without this attachment.
