Brief Description: Left Wing Ribs and Left Rear Spar
Clecoed Left Wing Ribs to Main Spar, bolted and riveted ribs as per directions. Trimmed the Aileron Stop Tab from 2 of the W-1013A's. Deburred and clecoed Left Inboard and Outboard Aileron Bracket Assemblies. Match drilled #30 holes and countersand holes as directed. Deburred Left Rear Spar and marked 2 W-1007D Rear Spar Doubler Plates. Matched drilled #30 holes in W-1007E and both W-1007D Rear Spar Doubler Plates. Marked and cut out Aileron Pushrod Hole into one of the W-1007D Double Plates.
