Brief Description: Ran Wiring for Right Wing Lights
Today I ran wire for wing tip lights in the right wiing. I ran a total of seven wires which I platted together to reduce any radio interference. Here is what is now installed in the right wing: For the future Aveo TL Landing Lights: 1. Landing Light---18 ga, shielded, white. Anticipate 1.35 amps at 14 volts. 2. Taxi Lights---18 ga. shielded, white. Anticipate 0.62 amps at 14 volts.(Could use 20 ga but I had some 18 ga) 3. Ground---18 ga. unshielded black. For the future Aveo Ultra Daylite Nav/Position/Strobe light: 4. Navigation/position light---20 ga. shielded, white. Anticipate 0.47 amps at 14 volts. 5. Strobe light---18 ga. sheilded, white. Anticipate 2.3 amps at 14 volts. 6. Strobe Sync Wire--20 ga. sheilded, white. Anticipate very little current. 7. Ground wire--18 ga. unshielded, black I cut all seven wires 19.5 feet long, braided then together and pulled through the rib grometts.
