Brief Description: Installed Bell Cranks in Right Wing
1. Laid out bolts, washers, plastic isolators, etc. to install bellcranks. I was short three 1/4" flat washers so I bought some from Home Depot. I went with stainless steel to guard against corrosion.
2. I put blue locktite on all six bolts used and bolted in the two bellcranks, Before installing safety wire I drilled four holes in the ribs to tie the safety wire onto.
3..Using 0.032" diameter wire I safety wired the four bekkcrank drilled bolts. Came out good.
