By adding a spacer underneath skin, between the bolt and longeron the warp does not show up when I tighten it down. I emailed the fix to Kerry at Sonex and will see what he says. In the picture you see a crude test strip that I stuck in there, but it was good enough to test the result and I am very pleased. I will conjure up something more nice and permenant if it passes QC.
