TERRY'S WEB SITE
Sonex
Continue AeroVee Engine Assembly
ACV-A01-15 Alternator Stator, 20 Amp, has only 16 gauge wire.
Install ACV-A01-15 Alternator Stator, 20 Amp, to ACV-A01-03 Alternator Mounting Plate (with ignition modules already attached), using Loctite 242 & ACV-Z01-76 x 4 Cap Screw.
Install Mounting Plate & Stator to accessory plate with ACV-Z01-12 Screws & Loctite 242.
Set electronic ignition timing.
Trim head studs x 4 to clear ACV-M01-11 RH & -12 LH Intake Elbow.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
