TERRY'S WEB SITE
Sonex
AeroVee Engine Assembly - 2nd Crankshaft Kit
I picked up my 2nd crankshaft kit on 11/21/2014.
After setting the crank into the crankcase half I have made the following measurements:
Prop hub flange face runout: .004"
Prop hub shaft runout: .005"
Install flywheel & determine shim stack height.
Crank end gap is .064 to .068 (this is not looking good, may have the same issues as I had with the original crank).
Use full shim stack of 5 as provided in kit, which measures .056" for a calculated end play of .008" to .012:"
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
