TERRY'S WEB SITE
Sonex
Continue AeroVee Engine Assembly
Check piston ring end gap:
#1 = .016"
#2 = .017"
#3 = .017"
#4 = .017"
Prop hub shaft diameter is 2.180", same original crank.
Attach left crankcase half and torque bolts. Cannot turn crankshaft 360 degrees without interference between crank and crankcase.
This is going to require investigation. I have contacted Sonex tech support.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
