Brief Description: Bundling & sorting wires, MAP sensor, Main Bus ...
...Main bus tray riveted together, Avionics Bus and Main Bus and keep Alive reinstalled. After panel was repositioned, wires were separated and bagged or routed. Grommets installed for main Bus. Heater GRD wire installed and labeled.Paul worked some of his magic knots that he learned in the USAF and will have lots more to go soon. Took photo of MAP sensor box for indexes for GRT EIS to set in at appropriate time.
