Brief Description: Soldered Keep alive, installed more CB, latch...
...Drilled lightening hole in bottom of fuel pump rack. Gale Derosier showed me how to solder and we did Keep Alive circuit wires. Installed 5 amp breaker for Alt field, 4 amp breaker for EFIS, Main Bus latch installed on bottom of panel. Drilled hole for AOA CB. Modifying panel with removeable throttle back plate which will allow panel to be removed by allowing the throttle, obviously attached to the engine, to remain in place while panel is slid aft. Using 5 nutplates to hold in place.
