Bobs Ten
Date:  1-28-2014
Number of Hours:  2.10
Brief Description:  Install Left ER Tank Fuel Pump
1442 - 1648
Route and secure pump wiring and stall warning wiring.
Verify pump runs with power attached.
Install fuel line from pump to bulkhead fitting, EZ Lube used on threads only.
Install ER tank.
Temporarily install fuel line from ER tank to fuel pump.
Route pump wiring and stall warning wiring so as to not interfere with anything in the pump bay or the aileron pushrod. Used nylon tywrap mounts to facilitate routing. Wiring then routed through previously installed conduit to root of wing.
Install premade flex line to bulkhead fitting.
Position main tank in proximity to wing location.
Connect flex line to fitting in main tank.
Install main tank on wing.
