Bobs Ten
RV-10
ER Fuel Tanks
10-25-2013
Fabricate Tank Tip Stiffeners
1148 - 1500
Fabricate tank tip stiffeners.
Layout and cut 3/4" angle.
Debur and smooth all edges.
Layout tip rib for rivets, drill pilot holes using #40 drill.
Cleco angle to rib, match drill holes.
Clamp 040 brackets to angles, match drill holes from skins where rivets were removed.
Remove stiffener assembly.
Final drill holes to mount brackets to angles using #30 drill.
Dimple all applicable holes for flush rivets.
Machine c-sink applicable holes in stiffener.
Debur and smooth all edges and holes.
Cleco stiffeners to wing structure.
Install ER tank, cleco at pilot holes.
Final drill tank mounts, rib, stiffener for AN3 bolt using #12 drill.
Fabricate rear mount doubler.
Cleco doubler to rib.
Final drill pilot hole using #12 drill.
Remove tank and stiffeners.
Locate and drill stiffeners for mount nut plates.
Debur all hloles, c-sink as required for nut plate mount.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
